DB-Cooper
Mar 14, 2019Guide
2.3.0.32 Update - Orbi Satellite Password Not Working
I updated my Orbi RB50K to 2.3.0.23, hitting the stop gap at 212. All was well, I was able to update and login to my RBS to get to .212. After upgrading my RBR to 2.3.0.32, I was forced to change the...
DB-Cooper
Mar 14, 2019Guide
When you click on that it prompts for password. This is if you do manual update.
I am using the web as well.
Mar 14, 2019Guru - Experienced User
Next step would be to factory reset the rbr50 and resync during setup as the satellite should be syncing from the main unit.
