DB-Cooper
Mar 14, 2019Guide
2.3.0.32 Update - Orbi Satellite Password Not Working
I updated my Orbi RB50K to 2.3.0.23, hitting the stop gap at 212. All was well, I was able to update and login to my RBS to get to .212. After upgrading my RBR to 2.3.0.32, I was forced to change the...
DB-Cooper
Mar 14, 2019Guide
After updating, I set the old password and now it works on both the Satellite and Router.
I'm not convinced that was the issue, I think it may have also been that I used the new password recovery thing and then disabled it. I happened to do that at the same time as changing the password. Given the password never changed, was working and it was broken, that is one variable that could've caused it, enabling that new PW recovery on the new firmware.
I can't really prove that now, but if someone else reads this and has the same issue, try disabling the new PW recovery option on the router and then try. If that doesn't work, one more password set should probagate and let you know.
Thanks for all the suggestions.
