jtalcott
May 11, 2019Tutor
2.3.1.60 everything went to crap
Orbi system has been fantastic and rock solid since the day I bought it. Today I was in the app and it said “new firmware available” and I updated, and it was the last time anything worked. The app up...
- May 11, 2019
jtalcott wrote:
........... Internet is constantly dropping in and out, and the satellites occasionally connect, but the whole system is effectively down for any wireless use, only devices connected directly to the router work with any sort of consistency. Any ideas of what to do?I saw similar issues after updating to 2.3.1.60. I think that something is wrong in the Satellite software. I solved this as follows:
- Power off the Satellite
- Go to "Attached Devices" in the web GUI, and click on "Remove" or "Forget" device for the Satellite that you powered off.
- Now power on the Satellite and then use a paper clip to factory reset it.
- When the Satellite comes up press the Sync button on the Router and then on the Satellite to connect the Satellite to the Router
- That's it, when the Satellite comes up things will continue working as they should! :)
Good luck
ekhalil
May 11, 2019Master
Good luck
- jtalcottMay 14, 2019TutorThis worked for me! Back up and stable so far for over a day. Thanks!
- cdnSpinalTapMay 14, 2019Guide
jtalcott wrote:
This worked for me! Back up and stable so far for over a day. Thanks!Hi jtalcott,
Can you confirm which steps you followed? If I am reading the thread right and "Solution", the following steps resolved your issue, correct?
