AFD
Oct 12, 2019Luminary
2.3.5.30 - ORBI - Firmware AutoUpdate? Severe Problems with Satellite
Someone could help me in order to know why my devices appear with the referenced firmware? I didn't perform any action to start an update procedure and the firmware was installed without any single m...
- Oct 19, 2019
Up & Running with 2.3.5.30 .
Almost 2 days with no (bad) news . Everything seems to run fine with no noticed issues (until now).
Satellite Devices are connected as expected .
Cameras running ok
IR/RF remote controls , devices and RF lights are operating as expected . (RF is posted because the remote controls are connecting to Orbi wia WiFi and send RF signals to different devices)
Keep you posted in case of problems .
Thanks to everybody for helping and supporting
mathewbeall99
Oct 13, 2019Aspirant
Well - I factory reset everything.... always fun to spend 45m doing that. We will see if it's more stable.
I don't even see an option that says "don't update firmware" in my version, unless its hidden somewhere.
Oct 13, 2019Guru - Experienced User
It didn't say don't update my firmware. It just doesn't update unless you click on the notification at the top.
- AFDOct 16, 2019Luminary
Start testing with the following Steps
1 - Start disconnection (turn off-on) of each device thta supposed to be connected to the satellite (more than 20 devices)
2 - Verify the connections
3 - Depending on the results 1-2 go to factory reset and reinstall 2.3.1.44 (manually)
4 - Restore the previously config file saved 2 months ago .
Thanks for all the collaboration and support . Im going to keep you informed about the results
By the way , it seems that unstable wifi is better now (I dont know why , because I didn't perform any action , but let's see)
- AFDOct 17, 2019Luminary
Problem solved(??) for the moment , status follows
This is the Method I used in my case
1 - Factory reset
2 - Manual installation Firmware 2.3.1.44
3 - Load Configuration file from Backup
4 - Testing everything with old firmware (OK)
5 - Manual installation Firmware 2.3.5.30
6 - Turn OFF/ON all the devices that supposed to be connected to the satellite
7 - Testing everything since 2 hours ago (seems to be ok)
Let's see what happen . Firmware 2.3.5.30 (up and running) .
- FURRYe38Oct 17, 2019Guru - Experienced User
Kewl. Keep us posted on how it goes...
