ekhalil
Jul 29, 2019Master
2.3.5.30: Wrong behavior when logging in from multiple computers
In previous firmware releases, when you try to log in to the web GUI using orbilogin.com or 192.168.1.1 and you're already logged in using another computer, you would get a question if you want to co...
CrimpOn
Jul 29, 2019Guru - Experienced User
Not my experience. Attempted just now and got the same response as usual. Did I want to log out the the already logged in user.
RBR50 on v2.3.5.30.
Maybe there was "something going on at the time" that had the Orbi confused?
ekhalil
Jul 29, 2019Master
Thank you CrimpOn . Good to know that it's working as it should for you.
I tried from different computers and I always get the same result --> Internal Server Error
Not a big deal for now, I don't want to reboot Orbi just for this. I will hold on with this until later. :)
- CrimpOnJul 29, 2019Guru - Experienced User
Reboot is pretty easy to time for me. "Reset to factory" is the one I dread.
