Daveapatton's avatar
Apr 08, 2017
2.4 G and 5 G - cannot get my orbi router & 2 satellites all under one 'network'
I set up my system. Created the network name.
On my iPhone when I go into settings and look under the Wi-Fi section I see several network's named "unknown".   When I look at the IP address or Mac addresses ( I don't know which one of those numbers I'm seeing on my iPhone),  I see several networks marked as "unknown" and they are the 5 GHz signals coming from my router. That leads me to believe that both frequencies are not bundled under my single network.
You will see in the picture below the name of my network is my last name, Patton.   You will see that the 2 GHz sIgnal IS part of my network but the one right underneath is coming from the SAME router (look at the IP address's.   The 2 GHz ( Channel 48) is part of my network but the 5 GHz signal (channel 157) is  not part of my network even though it's coming from the same router????
 Does anyone have any idea what I'm trying to say, LOL? I'm clueless when it comes to tech. Need help please :-)
  • THANK YOU!! Man I please ask you another question? Since that network does not technically have a name, are my devices going to know that they can use the 5 GHz channel? I'm sorry I'm so stupid when it comes to this stuff :-)
    • rhester72's avatar
      rhester72
      Virtuoso
      Your devices will try to connect to the lower-channel 5GHz network (which has a SSID) if they support 5GHz, yes.  Nothing will attempt to connect to the higher-channel backhaul radio except the satellite/router.
      Rodney
  • Both channel 48 and 157 are 5GHz (by definition, 2.4GHz channels only go up to 11 in the US and 14 internationally).  The lower-numbered one is the Orbi wifi network, the higher-numbered one is the Orbi's backhaul-to-satellite connection.
    Rodney
