RV078
Jan 17, 2024Aspirant
2.4 GHz and RBR50 Orbi-suggestions not working
Hello I have an ORBI mesh network RBR50 with 2 satellites. I’m trying to get the Govee app working but it currently won’t recognize/connect to my wifi. I have tried all the suggestions on this forum:...
- Apr 24, 2024
I was in the same situation. I was trying to attach a Govee smart bulb (H6008) to my Orbi mesh (RBR50). I turned off the 5 GHz SSID broadcast and turned the power down to 25% (i.e., minimum). I changed the channel for the 2.4 GHz network (from auto). I "forgot" and then rejoined the network from my iPhone. Nothing helped. I waited several hours (with the new Orbi RBR50 settings) and it still did not work.
Then I set up a Govee account on my phone and tried again and it worked immediately.
I have no idea if it was a coincidence or if it changed something behind the scenes (the app did not report any changes or firmware updates), but the success was so immediate that I thought I should share. Hopefully, this helps someone else.
Also, I am running Router Firmware Version V2.7.4.24
I will try to attach some screenshots of the router settings that worked for me.
RV078
Jan 18, 2024Aspirant
Thank you.
Apple iOS 16.1.1, iPhone 14 pro
I am attempting to add some Govee lights, model H6008. While installing the device in the Govee app, it works fine via blue tooth, but the wifi connection cannot be established.
CrimpOn
Jan 18, 2024Guru - Experienced User
Amazon says they will be here tomorrow before 10pm. The reviews are 92% positive, so it will be interesting to see how the WiFi setup goes. (I can only do it on Android.)
- CrimpOnJan 19, 2024Guru - Experienced User
What a puzzle. My two-pack of Govee H6008 LED bulbs arrived.
Opened the Govee Home app on Android smart phone connected to the Orbi WiFi at 5G (not 2.4G)
Logged into Govee account.
Selected "+" to add new device.
Searched for H6008. Found light bulb.
App said to turn on Bluetooth (which was already on).
App asked for WiFi credentials
App says 'connected'
Govee Home turns bulb on/off. changes color. changes brightness.
Then.... Turn off WiFi on phone. Turn off Bluetooth on phone. Govee Home app still controls bulb. Not connected to bulb with Bluetooth or WiFi. The bulb must be connected to the Orbi WiFi and is being controlled through the Govee "Cloud" connection.
If this is not working on an iPhone...... I got no idea. Works fine on Android.
