krisb999's avatar
krisb999
2.4 GHz Device only connect to router and not Satellite
My setup is such that I have an RBR50 and two RBS50 Satellites.  I have been having issues with light bulbs disconnecting from the 2.4 GHz signal.  Tonight is the first time I noticed that all of the...
  • FURRYe38's avatar
    Dec 19, 2021
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings.
