krisb999
Dec 19, 2021Aspirant
2.4 GHz Device only connect to router and not Satellite
My setup is such that I have an RBR50 and two RBS50 Satellites. I have been having issues with light bulbs disconnecting from the 2.4 GHz signal. Tonight is the first time I noticed that all of the...
- Dec 19, 2021
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?What is the size of your home? Sq Ft?
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings.
krisb999
Dec 29, 2021Aspirant
Thanks. I tried turning the power down to 50% on the router and that seems to have worked.
