happyintruder
Aug 12, 2019Aspirant
2.4 Ghz issues with nest cameras and zodiac iAqualink
I too was wanting to purchase the Orbi with 1 sattelite....but after reading these post, I am very hesitant....i also have Nest front door camera, 6 ADT cameras and a ZOdiac iAquilink system.....All ...
happyintruder
Aug 13, 2019Aspirant
thanks for the response......i am in discussions with Jandy concerning teh issues....will see what they come up with
CrimpOn
Aug 13, 2019Guru - Experienced User
Oh, heavens, YES, use the EXACT same WiFi name (SSID) and password. I have kept the same credentials through three router replacements. If you want to back, just plug in the old router.
What would prompt some to change from Velop to Orbi?
- happyintruderAug 13, 2019Aspirant
my Velops Router continues to receive internet from my cox modem and speed test show 50-95gbs down and 9,9 up while connected to the lan cable 7” away from modem and router…..across the other 2 satellites, they keep dropping off line…..Wireless connections are around 30 down adn 9 up…….called cox and they say I have everything goo…..so I think the router is bad.
