Kyle198
Jan 02, 2021Follower
2.4 to 5ghz
I need help, just bought an Orbi mesh system, i can't connet most of my lights and switches to 5ghz, is there any way to change it to 2.4? I'm a novice at this.
Jan 02, 2021Guru - Experienced User
try turning down the 5Ghz power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
You can temporarily disable the 5Ghz SSID broadcast as well.
