Rssteens
Jan 17, 2020Aspirant
2.4ghz device connecting to orbi rbk53
Hi, We have an old2.4ghz device we want to connect with the orbi rbk53. It does not connect. We have already tried to connect to another router with only has 2.4ghz and that worked. Is it possib...
- Jan 31, 2020
what I have found is that if i get far enough away from the router the the connection will fall back to 2.4G and once the item has connected it will stay connected fine.
schumaku
Jan 17, 2020Guru - Experienced User
As there is a lot of noise with similar issues, putting aside that a 2.4 GHz only device does not give a s**t if there is 5 GHz, 60 GHz, or whatever other standards technologies are on air: Please provide details of the 2.4 GHz device (make, model, firmware, installation process, ...) which does apparently fail to associate with the Orbi wireless
Worth a try: Temporary shutdown Orbi, configure the other router you have at hand to the same network name (SSID) and security key/password, and configure the device in question so it has the config ready. Now shutdown the test router and bring up Orbi again.
Just in case you are located in a regulatory area allowing to use the channels 12 and 13: You might want to change the Orbi config to channels 1..11. Few devices (not correctly adopted to the regulatory area, direct import, whatever) will not work on 12 and 13.
Rssteens
Jan 30, 2020Aspirant
Hi,
Thanks for your comment. I have given the test router the same SSID and password as the Orbi. The 2.4 GHz device connects to this test router. I then switched off this test router and switched on the Orbi. However, the 2.4ghz device does not connect to the Orbi. The WiFi channel of the Orbi is at 11.
The 2.4 GHz device is the WiFi ITC from Faber. There are no more specifications
Hopefully someone can help us.
