spopat
Mar 26, 2020Aspirant
2.4GHz device won't connect to Orbi
I am trying to set up a device that only works with the 2.4 ghz band and has to be set up using an app on my SM-G975U. For this device, it asks me to select the wifi network (from a list of all vis...
spopat
Mar 28, 2020Aspirant
Thanks - I tried that unfortunately it didn't work. The device I am trying to connect which is 2.4Ghz is called Rotimatic. Flat bread maker.
Yes I have 2 seperate SSid for 2.4 and 5Ghz. Tanjs
CrimpOn
Mar 28, 2020Guru - Experienced User
spopat wrote:The device I am trying to connect which is 2.4Ghz is called Rotimatic. Flat bread maker.
Well, with separate SSID's for 2.4G and 5G, and the phone connected to the 2.4G SSID, then my guess is it has to do with the instruction to ensure that "mobile data is turned off". https://support.rotimatic.com/en/articles/2057555-unable-to-connect-to-wi-fi
I have run into this before When the Rotimatic app connectes to the Rotimatic WiFi web site, it will get an IP address from the Rotimatic, but will have no internet connection (because the Rotimatic is not yet connected to the Orbi WiFi.) Phones hate having no internet, so many phones will say, "Oh, look. Here's my LTE connection. IT has data. Let's do that." This screws up the connection to the Rotimatic, and the phone app just sort of dies.
On my Android phone, there is a slider to disable mobile data. I know nothing about iPhones.
