rolandbarnes981
Jun 24, 2021Aspirant
2.4Ghz network disappeared in office
Hi there all, Any feedback appreciated - I have the three pack RBK53S and have been overall very happy with it. It was purchased to extend the wifi down to the bottom of the garden into a hom...
- Jun 24, 2021
rolandbarnes981 wrote:My phone only has 2.4Ghz wifi and used to have a very good signal down in office, but this has now disappeared, it cannot see the Orbi network even when adjacent to the Satellite.
Does the phone connect to the Orbi 2.4G band in the house?
What happens if you swap the two satellites (window and office)?
Jun 24, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the Orbi system been performed since last update?
rolandbarnes981
Jun 25, 2021Aspirant
Yes - thanks power off sorted plus moving office satellite to have clear view of bedroom one.
Many thanks all
- FURRYe38Jun 25, 2021Guru - Experienced User
Enjoy.
