Retired_Member
Jul 11, 20172.4GHz speed limit
Hi guys, I own RBK40 system, when I enter configuration page, I found that the mode of 2.4GHz is in "up to 192 Mbps", no matter how I try, it still limit to 192 Mbps. How can I achieve 400 Mbps in 2....
DarrenM
Jul 12, 2017Sr. NETGEAR Moderator
Hello Paradoxes
Do you have a 802.11n device connected to the network? If so this could be bringing the connection down to that speed.
DarrenM
- JMU1998Jul 12, 2017Luminary
Now I have a 2.4GHz radio on for which I have zero use contributing to the interference in an already congested neighborhood and NO way to turn it off or turn the signal down!! How nice to have a 2.4GHz radio with no assigned SSID running for which I have no use brilliant design! Why Netgear why did you take away the ability to turn off or reduced power on 2.4GHz?
