Retired_Member
Jul 11, 20172.4GHz speed limit
Hi guys, I own RBK40 system, when I enter configuration page, I found that the mode of 2.4GHz is in "up to 192 Mbps", no matter how I try, it still limit to 192 Mbps. How can I achieve 400 Mbps in 2....
DarrenM
Jul 13, 2017Sr. NETGEAR Moderator
Hello JMU
I am going to ask about and pass along the community feedback about the 2.4ghz power level and the option to disable it.
DarrenM
JMU1998
Jul 13, 2017Luminary
DarrenM thank you and much appreciated, we should have atleast 1 option at a minimum either ability to disable or reduce power on 2.4GHz as everyone's environments are different especially environments already saturated with radios, allowing us to lower or turn off what is not needed.
