thedak
Feb 19, 2017Apprentice
2.4GHz wide mode
I have an RBK50 + satellite set up. Set 2.4ghz band with 20/40 co-existence unchecked. Tried channel selection of auto, 4, 5, and/or 9. All of them show up as narrow (20) width with a single c...
- Feb 19, 2017
Maybe because you have interference from neighboring access points, or because you have a non-40MHz capable device connected.
Unless you live in the middle of a farm and have no other WiFi access points nearby, best practice is to use channels 1, 6, or 11 with 20 MHz bandwith.
If you use 40 MHz, or if you use different channels than 1/6/11, you increase the potential for interference from nearby APs and other devices operating in the same frequency band, like Sonos speakers.
st_shaw
Feb 19, 2017Master
thedak
Feb 21, 2017Apprentice
thanks!
