Mr_DRS
Apr 09, 2020Star
2.4gz channel stopped broadcasting
Hi last night for no reason my 2.GHz channel stopped broadcasting. My 5GHz channel and wired devices are fine. The reason I know that it is a fault with the 2.4GHZ channel is because all my smart...
- Retired_MemberApr 09, 2020
FURRYe38 wrote:Please try a factory reset and setup from scratch with the RBR and RBS. Let us know if the radio returns...
Be sure all other wireless radios are disabled on the SKY Q Router...
Please allow the OP to investigate/research this fouled up FW
Retired_Member
Apr 09, 2020
Mr_DRS wrote:Hi last night for no reason my 2.GHz channel stopped broadcasting. My 5GHz channel and wired devices are fine.
The reason I know that it is a fault with the 2.4GHZ channel is because all my smart cameras which use that channel have all gone offline and wifi analyzer shows no ssid being broadcast on the 2.4ghz channel.
My support just ran out in February so wondered if the community can help. So far I have rebooted the router, tried disabling then reenabling the 2.4Ghz broadcast, but nothing has worked.
My router is RBR50 with one satellite version v2.5.1.8 . I have it set up in AP mode with a SKY Q Router ding the DHCP routr stuff.
Any help would be really appreciated.
how long have you had v2.5.1.8?
lots of problems, you may want to dump it and swtich back to your previous version.
