CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
Same as before. RBK50 working well after FW update to v16. No factory reset since coming back from Voxels FW.
SLK-Purdue
Apr 30, 2020Luminary
Been running 2.5.1.16 for a week without any problems. Device discovery does seem to be improved and, so far, the WebUI info matches the app info. No other items noticed. My changes to DEV_show_device.htm to add column sorting work in 2.5.1.16 without change.
Scott
