CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
cdzo72
May 01, 2020Apprentice
Since flashing 2.5.1.16 I haven't noticed any of the issues I've had in the past giving problems...
1) Disney Circle seems to be working fine. Adjustments can be made in Circle app and Orbi reacts as it should without having fits.
2) Fewer false alarms and false positives from Armor. It got so bad that I tried sending a bug report to Bitdefender and the Orbi wouldn't even capture its logs. All seems well now.
3) DHCP reservations were causing device disconnects. All seems to work as it should.
4) Device naming and icon assignments seem to be sticking between app and Orbi GUI... but I wish that there were the same selection of icons in the app as in the web GUI.
