CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
changds
May 03, 2020Guide
Fixed (so far): 2.5.1.16 seems to be better at maintaining continuous wi-fi signal. On 2.5.1.8, the RBS50 satellite would appear reboot itself several times a week (as evidenced by loss of coverage for several minutes and the appearance of the blue ring). Fingers crossed on results as the week progresses.
Side note: when I first upgraded to 2.5.1.16 and did a factory reset, the RBR50 router couldn't connect to the WAN (a big red "NO INTERNET"). After a couple of reboots, it was able to connect. Not sure if this was a one-time problem, but it does make me reluctant the next time I have to reboot the router.
