CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
cdzo72
May 03, 2020Apprentice
Have you tried generating new passkey?
steve8411
Pass key? As in WiFi password? If not, then that's a new one for me. Please explain.
- cdzo72May 03, 2020ApprenticeGo to Advanced/Advanced Setup/Wireless Settings and look for Backhaul Password/Generate.
It's the passkey between router and satellites... it generates it's own, also, you may have to manually sync using the sync button on the router/satellites - steve8411May 04, 2020Apprentice
It's the passkey between router and satellites... it generates it's own, also, you may have to manually sync using the sync button on the router/satellitesI'll give it a go when I finish work today and report. Thanks!
