CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
cdzo72
May 03, 2020Apprentice
Go to Advanced/Advanced Setup/Wireless Settings and look for Backhaul Password/Generate.
It's the passkey between router and satellites... it generates it's own, also, you may have to manually sync using the sync button on the router/satellites
steve8411
May 04, 2020Apprentice
I'll give it a go when I finish work today and report. Thanks!
