CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
cdzo72
May 04, 2020Apprentice
"Unfortunately, the satellite ethernet ports work for the backhaul but not a client."
Not sure what this statement means. The RBS50s are basically a wireless switch, unmanaged switch. Wirelessly connecting to clients and backhauling to the RBR50 wirelessly or via ethernet.
MainerH55
May 04, 2020Aspirant
My RBS20 has two ethernet ports, one being used for the backhaul and the second I hoped to wire to an Ethernet device.
A few older posts indicate that this is a firmware issue, not a configuration or hardware issue.
