CrimpOn
Apr 30, 2020Guru - Experienced User
2.5.1.16 Results Only
Could we please have a post that ONLY contains reports of firmware 2.5.1.16? i.e. "My Orbi is now at firmware 2.5.1.16 and I observe: No change. Everything is the same as before. What worked con...
changds
May 24, 2020Guide
We experienced the same thing. Our RBS50 satellite seemed to be the culprit and bring down the whole network for 5+ minutes while it rebooted. After multiple attempts at firmware changes, gave up. Bought the SRK60 Orbi Pro (which runs on different firmware) and has been stable for 8+ days so far.
May 26, 2020Guru - Experienced User
Press the back reset button for 15 seconds then release.
changds wrote:We experienced the same thing. Our RBS50 satellite seemed to be the culprit and bring down the whole network for 5+ minutes while it rebooted. After multiple attempts at firmware changes, gave up. Bought the SRK60 Orbi Pro (which runs on different firmware) and has been stable for 8+ days so far.
