cliyeh
Oct 03, 2022Aspirant
2.5 GBps Switch
Hello, Was wondering what's the best way for me to add in my 2.5 GBps Switch. I currently have 1GBps ISP and have things connected from ISP Modem - RBR50 - PC/TV/etc. Was wondering if it's p...
cliyeh
Thanks for the reply. Yes I know typically switch will go after router. I'm trying to avoid upgrading a new router. I only have 1 device (PC) that is capable of going past the 1 Gig, that's why I wanted to split that connection out and then use the orbi for my wifi. Can it be setup as an access point that way?
CrimpOn
Oct 03, 2022Guru - Experienced User
The key item of information is the ISP device.
- If it is "only a modem", then the Orbi needs to be connected directly to it and be in router mode.
- If the ISP device is actually a combination modem/router, then yes, the Orbi can be placed in Access Point (AP) mode.
There are two easy ways to determine this:
- If the ISP device has only a single Ethernet port, then it is almost certainly a modem. If it has more than one Ethernet port, then it is probably a router.
- Does the Orbi web browser interface, Advanced Tab report the Internet Port IP address as a public IP or as a Private IP?
https://en.wikipedia.org/wiki/Private_network A public IP indicates the ISP is a modem. A private IP indicates that it is a router.
