khawe
Apr 06, 2021Tutor
2 Days of trying to connect Orbi - no luck.
Tried Netgear support - no answers. I have been trying for 2 days to get my Orbi to work. I use the app and it says it cant connect to my wifi network - i go through all the trouble shooting - nothin...
vajim
Apr 07, 2021Master
Ha_Ku_Na wrote:
khawe wrote:Tried Netgear support - no answers. I have been trying for 2 days to get my Orbi to work. I use the app and it says it cant connect to my wifi network - i go through all the trouble shooting - nothing. Power cycle, nothing. New System setup. Nothing.
Any guidance on what to do or where to go before I return this?
Follow the setup guide:
https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite
You have not mentioned what exactly is not working.
he/she has a modem/router combo I believe....
Ha_Ku_Na
Apr 07, 2021Luminary
Double-NAT is in most cases not an issue. Most routers offer a way to set "static routes".
But this requires a configuration on the "other" (non ORBI) router.
- vajimApr 07, 2021Master
Ha_Ku_Na wrote:Double-NAT is in most cases not an issue. Most routers offer a way to set "static routes".
WRONG....this forum is filled with 100's and 100's of folks buying modem/router combos or trying to run a 2nd router with the Orbi. They have no idea how to hook it all up and and end up in here asking the same questions.
- Ha_Ku_NaApr 07, 2021Luminary
You are wrong, as I wrote, most actual routers offer a way to set static routes. With this way, you can use the ORBI behind another router in router mode and use all features the ORBI offers. I have two routers and configured the ISP provided router with a static route to the ORBI.
ISP -> ISP Router -> ORBI -> wired device 0
-> WIFI devices 1-n
-> switch 1 -> wired device1
-> wired device2
-> switch 2 -> wired device3
I also have several switches in different floors of my building.
All devices are connected either wired to one of the switches or via WIFI via the ORBI WIFI network.
You see, practical experience, not just "reading" ;-)
ISP -> ISP Router -> ORBI -> all devices are connected to the ORBI either wired or wireless
WRONG again.....welll I suggest you go public and explain all of this great wisdom you have. Just because you know how to deal with double NAT settings doesn't do a thing for the multitudes coming in here and asking how to fix it. Do yourself a favor a perform a simple search and while you're at it go ask your buddy FURRYe38 for he keeps the double NAT response in his quick copy/paste file.
From reading your last incorrect post here, you make it sound there are NO postings in this forum from people with double NAT issues. Do you feel OK..??
