khawe
Apr 06, 2021Tutor
2 Days of trying to connect Orbi - no luck.
Tried Netgear support - no answers. I have been trying for 2 days to get my Orbi to work. I use the app and it says it cant connect to my wifi network - i go through all the trouble shooting - nothin...
Apr 07, 2021Guru - Experienced User
I use double nat too sometimes. Had my Orbi RBR behind a NON NG router. Works well with DMZ. Though I don't recommend this for everyone.
The user has been set on a path to correct there problem. I'm sure they will respond back here when they get progress.
vajim
Apr 07, 2021Master
FURRYe38 wrote:I use double nat too sometimes. Had my Orbi RBR behind a NON NG router. Works well with DMZ. Though I don't recommend this for everyone.
Thank you for a level headed and honest response.
- BoilerPlateApr 07, 2021Apprentice
Vajim's lack of knowledge and experience, your mileage may vary. >vajim. User beware. :smileysad:
Sad that he has to spread false and inaccurate information and badger and troll others that are just providing help to others. Must have a sad life.
:smileysad: - vajimApr 07, 2021Master
BoilerPlate wrote:Vajim's lack of knowledge and experience, your mileage may vary. >vajim. User beware. :smileysad:
:smileysad:Please stop these personal attacks. BoilerPlate should be banned
Stop playing the victim. You instigate ALL of this. Your the one who should be banned.
Please NG, BAN vajim. PERMANENTLY. There are others in the forums trying to help users out. vajim does NOTHING to help anyone!!!
BoilerPlate wrote:Stop playing the victim. You instigate ALL of this. Your the one who should be banned.
And what are you doing? Why are you posting here other than to try and beat me up. What's your purpose?
Now go away and behave yourself.
