jackalt
Jan 25, 2025Aspirant
2 different networks with one orbi router
Hey everyone! I recently set up an Orbi RBK50 mesh system with one RBS50 satellite, and so far, I’m loving the speed and coverage. However, I ran into an issue: I connected the Orbi router to my loca...
jackalt
Jan 26, 2025Aspirant
Thanks for you answer.
How do I turn off the ISP Wifi so I only keep the Orbi Wifi working?
michaelkenward
Jan 26, 2025Guru - Experienced User
You'll have to check the details of the local Wi-Fi provider’s router for that information. It may have an on/off switch somewhere, or you may have to go into a web browser and the graphical user interface (GUI).
What is the local Wi-Fi provider’s router? Is it also a modem that connects you to the internet? Or just a router?
If it is a modem/router you may be able to turn off the router bit completely and use it in modem-only mode.
If it is just a router, you might be able to do without it completely.
Just another user with time on their hands.
