Beachcomber09
Nov 29, 2017Aspirant
2 or 3 Satelites?
I am considering the Orbi to help extend my wifi range. I have High Speed internet currently from Comcast. The goal is to get the wifi to extend fully into my guest house. My set up is as follows ...
Beachcomber09
Sorry my mistake the questions should have been 1 or 2 satelites. I was referring to the router as a satelite in the original post. So the question is do I need the router and 1 Satelite or router and 2 Satelites?
Anonymous
Nov 29, 2017From what I understand, the Orbi is packaged with a square foot coverage rating, i.e. 5,000 or 7,000. This is probably a best guess for the major unknown is the actual makeup of the structure, walls, doors, etc.
I bought the AC3000 package (router + 2 sats) which I beleive is rated at 7,000 sq feet. My house is just over 2,000. However I wanted coverage in the backyard as well as wifi speed transfer between the router and devices. I use SlingTV.
My recommendation would be to purchase what you can afford. The Orbi appears to be a solid performer and if one sat is not enough for you I beleive you can add more. Good luck!
