D3xter
Jan 14, 2020Aspirant
2 Orbi Router im selben Netzwerk betreiben
Hallo Community , ich möchte zwei Orbi Router einmal den Pro und einmal den normalen im selben Netzwerk betreiben, da ich insgesamt acht Sateliten benötige. Ist dies generell möglich ? Ei...
D3xter
sorry, for posting this in the wrong Language.
Translation
I want to configure two Orbi Routers in the same Network is this somehow possible?
I need eight satelites so I need 2 Routers (the normal one and the Pro).
One Problem with the Configuration could be that I need to configure the routers over the same IP which could lead to a problem.
I hope anyone can help with this.
Thanks in advance :)
- FURRYe38Jan 14, 2020Guru - Experienced User
You can configure one RBR for AP mode while the other is in router mode. 2 routers can not occupy the same IP address pool string.
