hcch
Jul 04, 2020Aspirant
2 PC computers can not connect to orbi wifi
I just got this orbi and I can not connect via wifi 2 PC computers. I really do not know what to do. One has this wifi adapter TP-Link TL WN725N N150 USB and the other one has an intel dial band...
- Jul 05, 2020
when first setup, I tap on the check for updates and there was an error so I continuied. Later I updated manually to the latest firmware.
After setting up the wifi I was just using an Ipad and my mobile phone via WIFI with no issues. I tryed to connect my main gaming pc with not success, I really did not pay any attention to it,then I configured all the mobile devices and some other thins like smart tv's and such.
When trying to connect one of my daughters PC it gave me an error even prior to the wifi password window. I tryed some local settings check but the sgrangest thing is that I use to have a Nighthawk router and never had that kind of issue. Then I thought it was due to the cheap TP Link micro wifi adapter that is connected on that PC.
After that I try to connect my gaming pc same thing and after that same results with my alienware r3 laptot so It was clear that it was not my devices fault so I went to check all orbi settings. Turns out that when I changed de SSID the problem was solved.
Thanks all for your kind support
Jul 04, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Turn OFF The RBS and just use the RBR to try and get the PCs connected first...
hcch wrote:I just got this orbi and I can not connect via wifi 2 PC computers. I really do not know what to do.
and the other one has an intel dial band AC7260 adapter
My model in the box states is the RBK43 the one that has 2 satelites.
I will never thought that this could happend, and I really do not want to think that it can only run with some wifi adapters and some others do not.
Thanks in advance for the support.
hcch
Jul 05, 2020Aspirant
- Mikey94025Jul 05, 2020Hero
hcch wrote:After that I try to connect my gaming pc same thing and after that same results with my alienware r3 laptot so It was clear that it was not my devices fault so I went to check all orbi settings. Turns out that when I changed de SSID the problem was solved.
Glad you were able to successfully connect your devices to your new Orbi.
One last recommendation - If your old SSID is still visible then perhaps your old wireless system is still running (in parallel to your Orbi). Turn off the wireless for that old device since you're now only using the new Orbi wireless network. This will reduce network congestion and confusion.
- FURRYe38Jul 05, 2020Guru - Experienced User
Glad you got it working.
If you changed the SSID name to something else and the PCs connected, this would seem to be a problem at the PCs. Problaby the wifi profile on these PCs should have been cleared or erased then setup again, then rebooted the PCs then attempt to reconnect to the SSID. This should have worked. Try this next time.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
hcch wrote:when first setup, I tap on the check for updates and there was an error so I continuied. Later I updated manually to the latest firmware.
