Hitman116's avatar
Hitman116
2 router failure at same time
Has anyone experienced 2 Orbi routers failing at the same time. Net gear modem works when connected directly to computer but both routers fail when connected to modem. They both show a solid purple and with no internet.
  • CrimpOn's avatar
    CrimpOn
    Can we back up a bit?
    What is the sequence of events here?
    I assume that there was one Orbi router connected to the modem and it failed?
    (there were not two routers connected at the same time).
    After the failure, a second Orbi router was connected and it never got connected?
    After that failure, a computer was connected directly to the modem, and it does connect?
    Was the modem reset (power cycle) between each attempt?
    • Hitman116's avatar
      Hitman116
      I have a Netgear modem connected directly to and Orbi router (Router 1).  From there I have a Netgear Ethernet switch which then is connected to another Orbi Router (Router 2).  Router 1 has a satellite connected to it.  On 12/17 both routers turned solid purple.  I factory rest both routers, also took it down to a single router.  All the same - solid purple.
      My guess was more to the group if they experienced anything similar in around the same time.  With the massive hacking going on, the timing is interesting.  It could also be that I just happened to have all my equipment flake out at the exact same time.
      Note:  This set up worked for a year with little to no issue.
      • FURRYe38's avatar
        What is the distance between the router(s)?
