alexsos
Mar 30, 2020Aspirant
2 routers? RBR40
Hi, My current setup: RBR40 as a router, 1 Satellite RBS40. Router connected to multi-switch resulting in LAN connection in rooms on 2-level house. I mostly use Apple family products and Sony. ...
alexsos
So what you are saying is that I can use satellite as a router through ethernet? I thought ethernet connections were only to connect satellite with outer hardware like a desktop. Now you're saying that they can be both? Any special settings for a satellite needed?
CrimpOn
Mar 30, 2020Guru - Experienced User
Sorry my answer was confusing. There is only one router, the RBR40. Any number of satellites can connect to it, and some of the satellites have ethernet jacks which computers and other devices can connect to - in addition to the WiFi connection. There will still be one connection to the internet (through the router). Adding a satellite with at least two ethernet jacks in the office will allow:
- The satellite to connect to the Orbi router at the highest reliable speed (over the ethernet cable), and
- Provide another ethernet jack for office use. For example, connect an inexpensive "unmanaged" gigabit ethernet switch to the satellite and then plug in computers, printers, laptops, etc. etc. to the switch.
- alexsosMar 30, 2020Aspirant
Now it's clear. I was looking for something cheap. I guess this one will work out when setup as satellite.
What do you think about it? RBR20
One in, one out and obviously WIFI out.
alexsos
