keithdigital
Jul 22, 2019Tutor
2019 Samsung TVs not connecting to 5GHz on Orbi (RBK50)
Hey I have about 18 wireless devices connected to an RBK50. All of them except 2 are connecting as expected (5GHz capable devices connect at 5Ghz unless they are really far then they connect at 2.4GH...
Jul 23, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
keithdigital wrote:Hey I have about 18 wireless devices connected to an RBK50. All of them except 2 are connecting as expected (5GHz capable devices connect at 5Ghz unless they are really far then they connect at 2.4GHz, etc..). But for some reason, my two Samsung Smart TVs (which are 5GHz capable) are connecting to Orbi at 2.4GHz (this happens 9 times out of 10). The TVs are very close to the Router/Satellite (approx 10 feet away) and there are devices a lot further away connecting at 5GHz. Why am I having issues with just these 2 Samsung TVs? Thanks.
Running Latest firmware V2.3.5.30 with factory settings.
- keithdigitalJul 23, 2019Tutor
I just contacted a Senior Tech at Netgear, they said there is nothing we can do to force Orbi to connect to the Samsung TV at 5GHz. Orbi choose 2.4GHz. He actually recommended returning the Orbi and getting something like a Nighthawk R7000 which would allow me to easily connect my devices to 2.4 or 5Ghz. What do you guys think?
Here's the info requested:
TVs: Samsung Q60R and RU7100 (both AC wireless capable)
ISP modem: Arris TM1602AHouse Size: 1300sqft 1st Floor, 1500 sqft 2nd Floor
Distance between Router and Satellite: Approx 15'
2.4GHz set to Auto (using channel 4)
5GHz set to 44 - I tried all the channels (36, 40, 44, 48).
WiFi Neighbors: 9 using 2.4G, 5 using 5G (channels 36, 36, 36, 157, 153)Enabling:
Beamforming (didn't try, Tech said this would not help my situation)
MIMO (didn't try, Tech said this would not help my situation)
WMM (was enabled with factory settings)Disabling:
Daisy Chain (didn't try, Tech said this would not help my situation)
Fast Roaming (was disabled with factory settings)
IPv6 (didn't try, Tech said this would not help my situation)
Set 20/40Mhz Coexistence to 40Mhz only (didn't try, Tech said this would not help my situation).- CrimpOnJul 23, 2019Guru - Experienced User
Well, the tech is right, and he's wrong. (1) He is correct that if it really important to have the TV connect at 5G, then there are products from Netgear (and everybody else) that will do that. However, what those products will not do is set up a seamless, "one WiFi name" network with amazing coverage and backhaul speeds. (2) He is wrong that the Orbi has forced a 2.4G connection. The Orbi broadcasts on both 2.4G and 5G and it is the device that chooses which one to use. I have lots of devices that support both 2.4G and 5G, and a lot of them pick 5G. It appears you also have a lot of devices which choose 5G and two Samsung TV's that do not. Maybe searching Samsung support sites will turn up a solution.
I suspect his reasoning was, "This guy is not going to be happy with Orbi. He should take it back and get something else. Problem solved."
Yeah I was shocked when he recommened buying a lower cost router (Nighthawk R7000), but then I found out that is what he uses and is very happy with it.
