keithdigital
Jul 22, 2019Tutor
2019 Samsung TVs not connecting to 5GHz on Orbi (RBK50)
Hey I have about 18 wireless devices connected to an RBK50. All of them except 2 are connecting as expected (5GHz capable devices connect at 5Ghz unless they are really far then they connect at 2.4GH...
Jul 24, 2019Guru - Experienced User
What happens if you uncheck the Enable 2.4Ghz SSID Broadcast under Advanced Tab/Advanced Settings/Wireless Settings and see if your TV connects and see if it's streams?
I would not hold to much confidence the TVs wifi adapter. They may not be well designed or tested.
Does the TV have a LAN port by chance?
keithdigital wrote:The speed test on the TVs showed 22 Mbps - my main concern. My laptop is getting 115 Mbps and it's located further from the router, but it's using 5 GHz.
keithdigital
Jul 24, 2019Tutor
Hey I disabled the 2.4Ghz SSID Broadcast, but the TV was still connecting to it and still was not able to see the 5GHz. I called up Samsung just for fun to see if they had any ideas but after explaining to them the story they pretty much blamed the issue on the Orbi router.
