keithdigital
Jul 22, 2019Tutor
2019 Samsung TVs not connecting to 5GHz on Orbi (RBK50)
Hey I have about 18 wireless devices connected to an RBK50. All of them except 2 are connecting as expected (5GHz capable devices connect at 5Ghz unless they are really far then they connect at 2.4GH...
keithdigital
Jul 24, 2019Tutor
Hey I disabled the 2.4Ghz SSID Broadcast, but the TV was still connecting to it and still was not able to see the 5GHz. I called up Samsung just for fun to see if they had any ideas but after explaining to them the story they pretty much blamed the issue on the Orbi router.
Jul 24, 2019Guru - Experienced User
Possible the wifi adapter in the TV is faulty...
Does the TV have a LAN port in back by chance?
- michaelkenwardJul 25, 2019Guru - Experienced User
Usually the best bet.
Samsung has never made it easy to connect devices with wifi. I find that LAN is easier to set up and more reliable.
I use Powerline Ethernet.
