MythicWeather
Aug 10, 2020Aspirant
2020 Orbi CBR40 drops internet connection; Wifi fine.
I have an ORBI CBR40. No sattelites. The orbi is acting as an all-in-one modem + router. Comcast is the cable internet provider. Orbi worked great for several months. Since mid july it has been e...
- Aug 10, 2020
SOLVED IT!
I decided to chat with an Xfinity rep to see if the problem was on their end / a modem problem they could fix. The problem was that the coaxial cable on the wall had come loose. The looseness was not noticeable at all until I touched it. Apparently the cables loosen over time due to vibrations and tension on the cable.
The moral of the story is two fold:
-Trust your customer service reps when they give you the "is it on, is it plugged in" checklist. The checklist works, and maybe you forgot a step.
-Tighten you cables before sinking hours into router settings.
MythicWeather
SOLVED IT!
Aug 12, 2020Guru - Experienced User
Glad you got it working. Thanks for letting us know.
Enjoy,
