Uplink01
Jun 14, 2017Star
2nd gen Eero announced.
Well. Eero just announced a new 2nd gen hardware, and I must say, I have pre-ordered it. Orbi raw speed is great (when it seems to work) but you have some major flaws that I just think it's time to...
peteytesting
Jun 15, 2017Hero
as a beta tester let me assure you they are working on it , its a complex system and the beta test guys have been working overtime including myself to try and ascertain and help fix issues , the main issue is the way the orbi works is totally different to anything else on the market so they have nothing to cheat against , so its baby steps but its getting better
i will say eero can put more effort in as its their only product , they live and die by how well or poor it does , netgear have many many products and tbh this diversity does stretch the netgear staff and capability somewhat , but i can assure you they are trying , this is the longest beta testing i have ever done so the effort is certainly there from us and netgear
i certainly can understand the frustration as it is expensive and the expectations are not lost in transit , i too can be frustrated at times but i think long term investment wise its worth it for you guys as the DW ( distributed wif ) way of doing what it does is far better than mesh for most households
imho its a matter of time b4 they find a balance between usability and functionality , its just taking longer than usual as its a bit like the first man on the moon , eg there are no foot step to follow and a whole bare ground in front of them to explore and understand , the whole ap and band steering alone does my head in lol
cheers
pete
nizmoz
Jun 22, 2017Apprentice
They been working on it for 9-10 months. I owned Orbi before my Eero now, and have had EERO for the last 4 months. ORBI was nothing but a disconnecting nightmare. Always promising they would fix the issue. Wasted so much of my time. Ignore Petey as he is a fanboy and ignores the fact the Orbi is a failure of a wifi system and terrible support. They don't seem to care to fix the issue. It doesn't take 10 months to get this issue fixed. I worked on enterprise grade hardware, and an issue like this would be fixed in just a matter of days.
- jleecloak1Jul 09, 2017Apprentice
