Uplink01
Jun 14, 2017Star
2nd gen Eero announced.
Well. Eero just announced a new 2nd gen hardware, and I must say, I have pre-ordered it. Orbi raw speed is great (when it seems to work) but you have some major flaws that I just think it's time to...
peteytesting
Jul 05, 2017Hero
sigh
but its not twice the wifi coverage or twice the throughput , all you get is a second 5 gig which wont cover any greater distance
the beacon units also dont have ethernet
and
- Malware protection and parental controls require subscription fee
how about read the reviews rather than just paraphrase the headings
Uplink01
Jul 06, 2017Star
peteytesting wrote:sigh
and
Sigh is right...
The beacons don't have ethernet, and neither does the Orbi Wall Plug Satellite... So what is the point you are making?
Also the 2nd Gen vs the 1st Gen are actually very differnet. The second generation units have better antennas and more sophisticated wave 2 radios with working beamforming/2x MU-MIMO and lower noise floors. Yes, they have also added a 3rd band, so you get 2.4Ghz, 5.2Ghz, and 5.8Ghz, and the TureMesh/eeroOS firmware figures out the best and fastest path for everything instead of just dedicating one channel to a backhall.
For extra Malware protection, and addtional content filters (You get parental controls, aka Family Profiles, for free) you can purchase Eero plus, but its completely optional. The best part IMO, if you choose to pay for it is the VIP support, that I actually used today under the 30 day free trial.
And yes, so far, my 3x 2nd Gen Eero (Wireless Pro) setup is out performing the Orbi (RBK50 setup) in everyway. Speedtests, stablilty, support, and well the Eero iOS app is just great...
I get that their is some beta firmware coming at some point (seems like we have been talking about it for how many months now?) and a new iOS app in the works, but its been a bit to long at this point for me. So much new hardware has come out from the Orbi team, but software wise, almost nothing??? Doesn't make sense to me when I see Eero releasing new hardware, with all new firmware for its 1st + 2nd gen Eero's, and all new updated apps...
- peteytestingJul 06, 2017Hero
apart from the rbs30 all other orbis do have ethernet ports
"so you get 2.4Ghz, 5.2Ghz, and 5.8Ghz,"
and still no increase in signal strength or coverage , beamforming works on the orbi and mu-mimo is useless for anyone that has more than 3 clients connected anyway its just an advertising gimmick
sorry but paying for anything after you have purchased a product just doesnt make sense
yer but didnt you have a faulty orbi kit ? so it would out perform it
just for your info there have been in excess of 20 firmware versions so far and there will be more
im glad you are happy with the eero but as i stated b4 its not twice as good as the original as the reviews seem to be claiming
- Uplink01Jul 06, 2017Star
peteytesting wrote:apart from the rbs30 all other orbis do have ethernet ports
And the Eero's also have ethernet ports, so again what is the point you are making?
I can't say that I agree with that at all. I actually had the 1st Gen Eeros (5 of them at one point) and I couldn't get above 150Mbps on speed tests in most rooms of my house. That is the main reason I switched to Orbi in the first place, as the Orbi had the "raw" speed. Since moving to just 3 new Gen 2 Eero's I get 350Mbps+ (more than my 300/20 internet) in each room, with no issues what so ever. So I am having a hard time saying that they have not been improved... Also it seems that they have a new firmware update coming out that is going to improve the "speed' even more in the future.
What doesn't make sense is to pay a bunch of money for a product that doesn't seem to work? What also doesn't make sense is to pay a bunch of money for something that continues to frustrate me? What does make sense FOR ME is to buy something that works much better, and actually gives me what I am looking for...
My experience with Netgear support has been very lackluster over the years. I actually went to best buy, purchased another Orbi setup, used it for 2 weeks, STILL had the same issues, and returned it. A friend of mine is also a having similar issues with his Orbi setup, and has also switch to the new Eero 2nd's (Eero + 2x Beacons) and is having a better experience overall.
Those "20" or so firmware updates are mostly labeled as "bug fixes." What are they fixing? Who knows... I haven't seen any major improvement to the dated Web UI, let alone that the iOS app has seen what one update since it was launched? Maybe two... I am not saying that the new firmware update (and iOS app) that is hopefully coming out soon will improve the experience for Orbi customers, but at this point it is way to late for me.
- nizmozJul 09, 2017Apprentice
Petey is a netgear fanboy. You have to ignore him. I've been here since the Orbi came out, and had Orbi before Eero and had all sorts of problems. After owning it for 6 months, I got fed up. I still see they have not fixed all the issues that I had with disconnects and their false promises. Glad I left them. I had some issues with EERO, but I upgraded to 2nd Gen EERO, and was able to work around the issues with their support as they are working on them still. But the speed is definitely faster now than the 1st gen. It is as fast or faster than my Orbi setup with more coverage than Orbi. EERO has completely upgraded the EEROs to the 2nd gen Pro setup. All new internals. We have better coverage and speeds. Petey has no clue what he is talking about in that case. He has never owned it. All the reviews even say they are better.
- peteytestingJul 09, 2017Hero
all those paid reviews you mean !!!! just like they also say the orbi is the best thing since sliced bread
the eero2 hasnt been in the wild long enough or in ppls hands long enough for any real knowledge of how they work long term , the eero 1 still has its issues for some users as does the orbi which i make no claim it doesnt still have un resolved issues
the only reason i havnt tested the eero is we dont have them here in australia , otherwise i would have tested them by now
They aren't paid. Denial from you is unreal. I've owned both Orbi and Eero 1st and 2nd gen. Which is more than you have ever done. Please stop posting BS you have no clue or experience about.
lol what a load or rubbish , almost all reviewers have some form of payment ether by keeping the product or like
so since you have owned both erro 1 and 2 please post test results and PROVE the eero2 is twice as powerful wifi wise and twice the coverage , put your money where your mouth is as otherwise your just blowing wind and trolling
some testing
"The Eero 2's performance is represented by the light olive-green bar. Netgear's router-plus-satellite Orbi wasn't always the fastest, but it was always much faster than the Eero 2."
from
the graph clearly shows an improvement from erro 1 to eero 2 but only that eero 1 was poor , eero 2 at least now runs with most of the pack throughput wise
- dmakogonJul 09, 2017Guide
An observation about the techhive testing: From what I read in that article, the Eero 2 test system is comprised of main unit plus two beacons. Based on my readings (including Eero's blog post), the Eero 2 Pro (which has three full Eero units) has better performance (though I have no idea how to quantify that).
I wonder how well the Eero 2 Pro performs, in comparison to the Eero w/beacons. I'd think that the Eero 2 Pro (assuming it does offer better performance) would be a more suitable A:B testing when comparing to Orbi.
- Uplink01Jul 09, 2017Star
dmakogon wrote:An observation about the techhive testing: From what I read in that article, the Eero 2 test system is comprised of main unit plus two beacons. Based on my readings (including Eero's blog post), the Eero 2 Pro (which has three full Eero units) has better performance (though I have no idea how to quantify that).
I think every test posted so far, at least the ones that I have read are solely testing using the Eero + two beacons (aka Home Wifi System), and to be very clear, the new Eero beacons are NOT Tri-Band, and are not as fast as the Eero's with Tri-Band. Also I assume they are using the factory 3.0 firmware, and not using 3.1 or 3.1.1 that clearly states "Improved performance for eero - 2nd generation.” To be fair, they typically don’t list what Orbi firmware they are testing against either.
"Or test the Eero 2 with the beacons against the RBK30 Orbi package."
I completely agree, most tests seem to be using the first RBK50, so if that is the case then they should be testing against the "Pro Wifi System" that comes with Tri-Band Eero’s, or switch to the RBK30 Orbi package for testing at this point.
Again, I personally have the "Pro Wifi System" so all Eero's that I am using are the Tri-Band versions, and I can tell you that they are MUCH faster than than the 1st Gens I had prior to my Orbi RBK50. So far the speed is equal, if not faster than my Orbi. They also seem to be much more stable than my Orbi, and that is super important to me. I also LOVE the Eero iOS App, it is just great.
Either way, this thread keeps going and going… Like I have said in the past, hopefully a new firmware comes out to fix some of the reported problems, hopefully it adds NEW features, improves the web UI, and a they release a new iOS app that actually is useful. If that happens, that is truly GREAT for the Orbi Community!!! Like I have already said, so far my personal experience with Eero support, the community involvement from the company directly, has been topnotch, let alone that you can clearly see from the updates to their apps & firmware they are very dedicated to making a great product. So even if, Orbi still wins the raw "speed" contest, it doesn't really matter to me anymore, as it is not just about that for me.
Good luck, and great competition tends to make all products better for all of us. :) - nizmozJul 10, 2017Apprentice
That isn't the pro system. Like usual you continue to spew stuff you don't have any experience with. I don't have equipment to test but from my experience around my house which you don't have there is a remarkable improvement. And the site you linked isn't a reputable company like CNET or others.
peteytesting wrote:
nizmoz wrote:They aren't paid. Denial from you is unreal. I've owned both Orbi and Eero 1st and 2nd gen. Which is more than you have ever done. Please stop posting BS you have no clue or experience about.
some testing
fro
Ding Ding Ding. We have a winner. You are correct sir. The eero pro is Tri-band system the other is not. I have the pro which is the one that beats the orbi system.
- martyfpJul 10, 2017Luminary
Anyone have any idea if Eero2 supports igmp snooping ? I can't seem to see any reference to it anywhere on google.
For me, that was the feature that pulled me towards orbi - although I've yet to get it to work
