Complexity
Apr 10, 2019Aspirant
2x RBK22 Costco
I have 2x sets of the below.
I want to link a satellite to another system. So to be clear I want to link a satellite that came with a router into a new router.
https://www.costco.com/Netg...
- Apr 14, 2019
Hi Complexity
Please use this link as reference of how to sync the router and satellite:
https://kb.netgear.com/31018/How-do-I-sync-my-Orbi-router-and-satellite
Blanca
Community Team
Apr 10, 2019Guru - Experienced User
Yes you can. Just know that the RBRs can not work as satellites.
Just factory reset the one RBS and then add it to the other system.
https://www.costco.com/Netgear-Orbi-Mini-2-Pack-AC2200-Tri-Band-WiFi-System.product.100398382.html
Does this work? Can I make it work?
Complexity
Apr 11, 2019Aspirant
I tried what you suggested. I verified that they are not RBRs, I have RBS'.
The issue is set it up after pressing the reset button and restarting the orbi satellite. And now the two satellites refuse to be on the same network map at the same time?
I connected them but they don't count or appear in each other's network map. Sometimes I get 1 orbi sometimes I get the other. but never both together in the network map.
I am not sure if it is working...
- FURRYe38Apr 11, 2019Guru - Experienced User
Is Daisy Chain enabled? Try that disabled...
DO they appear in the RBRs web page with a web browser?
- ekhalilApr 11, 2019Master
Complexity wrote:......
Please press the Sync button on the Router and then the Sync button on the new Satellite to make them sync together.
Or follow the "Add Orbi Satellite" in the web GUI as follows:
- FURRYe38Apr 15, 2019Guru - Experienced User
Any progress on this?
