Shady01
Jan 21, 2021Aspirant
4 Channels are not locked
just noticed that I have 4 channels are not locked
Shady01
it's the CBK752 build in modem and router + satellite..
my ISP is optimum.
What should I exactly ask them to do ?
I will check in the morning but I do believe there's a coax splitter outside my house between the ISP box and my house coax cable
my ISP is optimum.
Jan 21, 2021Guru - Experienced User
What speed package do you pay for? If it's not 1Gb download then your ISP might not have the 4 locked in as it's not needed. For 1Gb download speeds, they should be locked in to 31 or all 32 channels. Someting to ask them about.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
