lowepg
Feb 04, 2018Apprentice
4 satellites running fine...
Wanted to see if Orbi would function past the posted limit of satelites.... The router + 2 satelites was convering our house pretty well, but I wanted to ecxtend coverage into the yards. It didn...
st_shaw
Feb 05, 2018Master
It didnt see to like daisychain mode with the 4 satelites, but once I switched that off, everything conneced fine.
The bad news: the coverage outdoors is really disappointing. So this experiemnt will be short-lived, returning the extra satelites and ordering some legit outdoor access points to hardwire.
Ealier this week I was doing some work outside my house and my coworker and I were both able to get >25 mbps on our iPhones from more than 500 feet away from the house. That's with the Orbi router and satellite inside the house.
If your outside coverage is disappointing then the problem is probably something other than your Orbi.
You didn't say where you put your satellite when you tested outside, but you should get long ranges with the Orbi outside with clear line of sight to your client devices.
lowepg
Feb 05, 2018Apprentice
Sorry, but given the issues Orbi has JUST getting firmware correct, I dont think its safe to assume:
"If your coverage is bad- its probably due to something other than the Orbis"
Moreover, I dont think your experience is necessarily representaive of all cases. For example, our house is brick- so I would expect ANY wifi to struggle to get great coverage through brick walls.... hence my desire to try another satelite.
However, given the premium price for these things (especially if you add an outdoor satelite $$$$) - it should be near bullet-proof- and it ISNT. Not by a long shot. A orbi "3-pack" plus an outdoor unit would run right around $900. For $900, I want "AMAZING" - not "OK"
I had a wiring guy quote my $400 to run cat6 to all 3 floors of my house and one outside connection. Add 3 Ubiquity Pro APs and a edgerouter and you're looking at about $475 in hardware. So, just about the same expense.
Orbi's (assuming the firmware works on that day) vs hardwired Ubiquity Pro Access Points? That's like comparing a Prius to a Ferrari. No comparison.
