daDozer
Mar 27, 2020Tutor
400 Bad request after update 2.3.5.32
Why do I always run into some error when I update firmware on these devices? I went through hair ripping frustration last time with no internet connection, solving the solution with a manual update. ...
Mar 27, 2020Guru - Experienced User
Try a factory reset and setup from scratch.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
- daDozerMar 29, 2020Tutor
Hello Fury, I believe you have helped me in the past. I am running into more issues since my firmware update. Please assist me as I am working and going to school from home now, and I need access to the internet. I have an RBR40 and an RBS40. Recently, I updated the firmware to 2.3.5.35 on both devices. Previously, Ive had no issue with dropped connection or anything. Ever since this update, I have reset both devices, manually pushed the firmware update after downloading the files from netgear. The devices are continually dropping connection, but will reconnect after 5 minutes. Sometimes, the lights on the devices are blinking white as if they restarted randomly, and sometimes they don't blink at all but I have no connection, I have to restart each device and when they reboot I have connection again. I've dealt with my ISP and determined that they are not the issue.
Everytime I update my firmware, I run into issues with these devices. Please assist me in getting this fixed. When these are working, they are great. But when you guys push out an update it gives me hell.
- FURRYe38Mar 29, 2020Guru - Experienced User
Do you have Circle or Armor enabled on the RBR?
v35 version as applied from the RBRs web page seen there? I don't see v35 FW being available on NGs download site. Hmmmm
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- daDozerMar 29, 2020Tutor
It is firmware version 2.3.5.32. My modem is an Arris TM3402A. I've tried disabling what you recommended above with no success. I don't have circle, or armor enabled. I use a wifi analyzer and am using a channel that is unoccupied by any neighbors.
