daDozer
Mar 27, 2020Tutor
400 Bad request after update 2.3.5.32
Why do I always run into some error when I update firmware on these devices? I went through hair ripping frustration last time with no internet connection, solving the solution with a manual update. ...
daDozer
Mar 29, 2020Tutor
Hello Fury, I believe you have helped me in the past. I am running into more issues since my firmware update. Please assist me as I am working and going to school from home now, and I need access to the internet. I have an RBR40 and an RBS40. Recently, I updated the firmware to 2.3.5.35 on both devices. Previously, Ive had no issue with dropped connection or anything. Ever since this update, I have reset both devices, manually pushed the firmware update after downloading the files from netgear. The devices are continually dropping connection, but will reconnect after 5 minutes. Sometimes, the lights on the devices are blinking white as if they restarted randomly, and sometimes they don't blink at all but I have no connection, I have to restart each device and when they reboot I have connection again. I've dealt with my ISP and determined that they are not the issue.
Everytime I update my firmware, I run into issues with these devices. Please assist me in getting this fixed. When these are working, they are great. But when you guys push out an update it gives me hell.
Mar 29, 2020Guru - Experienced User
Do you have Circle or Armor enabled on the RBR?
v35 version as applied from the RBRs web page seen there? I don't see v35 FW being available on NGs download site. Hmmmm
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- daDozerMar 29, 2020Tutor
It is firmware version 2.3.5.32. My modem is an Arris TM3402A. I've tried disabling what you recommended above with no success. I don't have circle, or armor enabled. I use a wifi analyzer and am using a channel that is unoccupied by any neighbors.
- FURRYe38Mar 30, 2020Guru - Experienced User
Did you get the FW from the FW update section of your RBR? Was it auto pushed or did you have it update upon seeing that there was an upate available?
Has a factory reset and setup from scratch been performed since last update? YOu might do this and also power OFF the ISP modem for 30 seconds then back on. Then walk thru the setup wizard with a wire connected PC and web browser at 192.168.1.1 or orbilogin.com
daDozer wrote:It is firmware version 2.3.5.32. My modem is an Arris TM3402A. I've tried disabling what you recommended above with no success. I don't have circle, or armor enabled. I use a wifi analyzer and am using a channel that is unoccupied by any neighbors.
- daDozerMar 30, 2020TutorYes I downloaded it from the firmware section for my Rbr40. There was a text box to select your model and in doing so it brought you to a page you could download 2.3.5.32 firmware for both the RBR and the RBS.
I've actually performed a complete reset several times. I manually push the firmware update through with the img files downloaded from netgear. I've did also power cycle my modem after reset.
