daDozer
Mar 27, 2020Tutor
400 Bad request after update 2.3.5.32
Why do I always run into some error when I update firmware on these devices? I went through hair ripping frustration last time with no internet connection, solving the solution with a manual update. ...
Retired_Member
Apr 08, 2020
daDozer wrote:Why do I always run into some error when I update firmware on these devices? I went through hair ripping frustration last time with no internet connection, solving the solution with a manual update. I updated and now I can't access my router setup. I keep getting "400 bad request" when trying to access through orbilogin.net. I tried the app, and seems I can't even login as it's not recognizing my username and password.
Why did you update?
- daDozerApr 08, 2020TutorWhy? Because I got an email from netgear saying there was a security update I needed to run.
- Retired_MemberApr 08, 2020
daDozer wrote:
Why? Because I got an email from netgear saying there was a security update I needed to run.Not clear on why they send those out. You didn't have to update.
However, the only firmware updates you NEED are those that NG pushes automatically.
You may need to revert back to your previous version.
- daDozerApr 08, 2020TutorI've tried several different firmware downgrades over the past week or so. When I found one that worked, it didn't disconnect for several updates. Until my devices updated to the most recent firmware automatically. Any suggestions?
