tx_polkhead
May 19, 2021Initiate
400 Bad Request RBR50
I am using an RBR50 and an RBS50 (connected with wired backhaul) firmware is V2.7.2.104 on both devices. My ISP is Spectrum, I pay for a 200/20 connection that is consistently connected at 234/23. Modem is a TP Link TC-7620 which is DOCSIS 3.0.
I have beenusing these Orbis for over a year without issues. Set up was easy enough and it has delivered good if not great speed and connectivity throughout our home.
In Advanced > Security > Access Control > I get “400 Bad Request This server does not support the operation by your client.”
In Advanced > Administration > Attached Devices > I get “400 Bad Request This server does not support the operation by your client.”
I typically use Chrome but have also tried MS Edge and Firefox with the same results. Any ideas why I can’t access attached devices or access control?
i waited a few days for some response but none came, i did a hard reset and things work now.
- Blanca_ONETGEAR Employee Retired
Hi tx_polkhead
Welcome to NETGEAR Community!
Let me check this with the team and will report back with an update as soon as possible.
Please check your inbox. I have sent you a message requesting for more information.
Blanca
Community Team- tx_polkheadInitiate
Glad you got it working. Please mark your thread as solved so others will know. Be sure to make a backup configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy.
