tx_polkhead
May 19, 2021Initiate
400 Bad Request RBR50
I am using an RBR50 and an RBS50 (connected with wired backhaul) firmware is V2.7.2.104 on both devices. My ISP is Spectrum, I pay for a 200/20 connection that is consistently connected at 234/23. Mo...
- May 22, 2021
i waited a few days for some response but none came, i did a hard reset and things work now.
Jun 04, 2021Guru - Experienced User
FYI, NG development doesn't monitor these forums. And with all the posts thats generated, would be hard to keep tabs no everything. Users have the option to contact support directly which is encouraged aswell as contact NG forum moderators too. Let them know directly vs indirectly. Forums can only do so much.
Good Luck.
Lexx
Jun 04, 2021Tutor
Yes, I know they don't monitor. Their solution to everything is same as yours, restore factory settings. I did swear off Netgear once before but there isn't much choice in multi-satellite high-bandwidth wireless backhaul meshes. Initially, Orbi worked ok and so I stuck with it -- clearly should have instead stuck to my prior Netgear ban. I don't need luck, I and the world needs competent software for a change.
- FURRYe38Jun 04, 2021Guru - Experienced User
:smileywink:
