Whoisjr's avatar
Whoisjr
Follower
May 08, 2020
$400 for intermittent internet?! REFUND!
Time for a refund Netgear! I know you say you don't offer them, but neither does Best Buy after 6 months. Someone should own up to this!
Six months of beautiful internet. Followed by two months of terrible, frustrating internet. The connection is fine because I can switch back to my non-Orbi internet with great success. It is Orbi.
No one to call. I've tried all of the "fixes." $400 is way to much for the frustration, dropped calls, dropped Zoom meetings, interrupted movies, tv shows and games.
Oh, then today, I discovered that my registered Orbi devices are now not registered and I cannot get support online anymore. WHAT?!?!
I'm normally not a public posting type person, but I cannot get anything fixed any other way! SOMEONE FIX THIS!
  • michaelkenward's avatar
    michaelkenward
    What exactly is it that needs fixing?
    Beyond a vague reference to "frustrating internet" your message is silent on that.
  • FURRYe38's avatar
    Is the Orbi system operating in Router or AP mode?
    IF you want a refund, the place to ask about this is the place of purchase. The forum doesn't handle refunds.
