TXSWoodruff
Aug 23, 2019Aspirant
401 Authorization Error message
Just installed Orbi RBR40 and 3 satellites. Generally working well but receiving a 401 Authorization error on several devices, Apple iPad and iPhone. Other devices working OK. Devices working we...
- Aug 24, 2019
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
TXSWoodruff
Aug 24, 2019Aspirant
Thank you - yes I do see two private IP addresses when I do a traceroute (I am on a MacBook Pro). First IP address is the ORBI router, followed by the Excede WiFi Modem. Looks like we do have a double NAT.
Aug 24, 2019Guru - Experienced User
Couple of options,
- TXSWoodruffAug 26, 2019Aspirant
That took care of our issue!! I chose to disable the WiFi on our Excede Modem and then put the Orbi in AP mode. Your links and YouTube videos helped a ton.
We are up and running! We love the coverage and now, with our issue resolved, I think we are Orbi-fans. Thanks again.
- FURRYe38Aug 26, 2019Guru - Experienced User
Good to hear. Enjoy. :smileywink:
